Chevy Trans Mount Dimensions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2010, 12:07 PM
I'm building a frame X-member and trans mount for a 4 speed that came out of an S10 Chevy to go behind my almost stock SBC.
I hope to be able to replace the trans sometime in the future with a better 4 or 5 or 6 speed or even a powerglide depending what I find..... yup, that means cheap.
For various transmissions, I would like to know the distance from the back of the block or back of the bell housing to the rear trans mount bolts and the width between the bolts if you gents would be so kind.
Trans Type Back Block or Bell Housing to Trans Mount Bolt spread
This would be helpful in buiding an X-member that might not require much modifying for a change of transmissions.
Your comments and help are appreciated.
Old 02-06-2010, 07:03 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Here are some dimensions:
Sizes
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 11:06 AM
chevy 350 build up for 1981 trans am jarrettandroski Engine 7 08-02-2008 12:00 PM
trans swap for 50 chevy fitty cheby Transmission - Rearend 3 11-27-2007 07:35 PM
Trans Question on my 2001 Chevy Silverado albino2_wolf Transmission - Rearend 0 09-16-2007 07:30 PM
Chevy motor and trans dimensions Neophyte General Rodding Tech 4 06-04-2004 04:31 PM
