Chevy Transfer Case Speeds - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2006, 06:06 PM
Does any one no which chevy transfercase has the fastest lowend gear, speedwise.
Old 05-31-2006, 06:56 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Dont quite understand your question? Do you mean which transfer case highest low-range? Not quite sure why you'd want that but the NP205 has a 1.96:1 low range, not really all that low ...
Old 05-31-2006, 07:09 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Borg Warner 4482- 2.64 low
NV-242 2.72 low
NP-207 2.60 low
A swapped in Atlas will give you a 4.00 to 1 ratio ($$$)
A NP-205 with the NP-203 range case for a doubler will give you the same, BUT is a lot of work and HEAVY.
93 Gmc Yukon...transfer case strength...and supercharging TheZaZ Engine 1 02-18-2003 10:37 PM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 04:56 PM
76 chevy transfer case purplePeopLEater Transmission - Rearend 5 12-15-2002 10:54 AM
Aluminum Transfer Case Bigdude_79 Engine 1 12-05-2002 08:38 PM
turbo 400 with transfer case to 700-r4 razzle Transmission - Rearend 3 11-04-2002 06:12 PM
