Chevy Transmission swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2009, 06:31 PM
Hey guys, I'm hoping someone could help. I have a 51 Chevy with a 58 235, and a three on the tree, What tranny would fit behind it so that I could still use the driveshaft, and crossmember, I would like to put a four speed in it. Thanks for any advice
Old 01-17-2009, 02:27 PM
Not a 4 speed, but a three speed from a 47 to 54 1/2 ton truck will bolt up to the V8, and to the closed driveshaft.
Old 02-01-2009, 12:03 AM
how about a 5speed
I also have a 235c.i 56Chevy wagon and had a 3 on the tree,A 5 speed will bolt right to the bell housing.I went to the junkyard and found a trans. from a s10 pick-up 1985 to 1988 and pulled it out.The only changes are drive shaft ,clutch and shifter ends up under the front seat.My legs are short,I think if you put you're seat all the way back you'll make it.Any questions please e-mail me.
Old 02-01-2009, 05:51 AM
poncho62's Avatar
Wiki Edits: 5
56 Chevy has an open driveline, 51 is closed.......so that s10 thing won't work
Engine swap on a 1994 Chevy 1500 4wd stfinney Engine 7 04-14-2015 06:20 AM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Transmission swap rockmason Transmission - Rearend 3 12-05-2005 09:09 PM
8.1 marine spec engine swap into a 57 chevy pickup customike Engine 2 12-03-2004 11:19 PM
Stude to Chevy engine swap Dawger General Rodding Tech 3 07-11-2003 07:15 PM
