Chevy truck-700R4 Swapping questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2006, 07:23 AM
ok, here's one for you guys.
my truck is an 84 chevy 4x4, longbed. it currently has a 700r4 in it. I currently have the chance to buy an 86 GMC 4x4 with a 4 speed manual trans. , for dirt cheap. The question is, is it more trouble than its worth to swap the good 4 speed in and take the slipping 700r4 out? Can it even be done? the 86 is a short bed.
another quick question= if that cant be done, what about swapping in a turbo 350 or 400? what about the steering column?
I know this one should be easy for you guys
thanks in advance for any help
Old 02-11-2006, 08:28 AM
Swapping the auto for the manual is no big deal as long as you use the transfer case that is with the manual trans!
Be sure to swap trans / t-case mounts also.
If you have the entire donor vehicle, it should be a breeze. Don't forget driveshaft lenghts may be different as well as your clutch pedal and linkage!
Not bad if you don't mind the work.
If you go to a th350 or 400 the t-cases adapters are different for all of these.
Just make sure you do your homework before ripping her down.
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
66 chevy truck frame swapping ezoo Suspension - Brakes - Steering 9 01-13-2003 04:58 AM
