Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Chevy Truck Bench Seat
  #30 (permalink)
Old 10-29-2007, 09:28 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Mark: You did a nice job on the seat repair. This is exactly why I save all my smaller pieces of thicker foams. It saves having to fabricate the right thickness. I'm curious why you think you only had one piece of polyurethane foam around? I would be surprised if you had anything but polyurethane around. About the only alternative to polyurethane is latex foam which is about 5 times more expensive.
Also, while contact adhesive will work for this job, dedicated foam to foam glue would have been the best choice to make your repair with, and spray grades of either one would also have been better because the formulations are adjusted to let them atomize from an aerosol can.
