chevy truck door handles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 10:10 PM
Got an 84 chevy blazer. Does anybody know how to get the door handles off? They are loose but I am not sure how to disconnect the linkage.
Old 11-08-2009, 10:25 PM
Pistonman's Avatar
Outer? Pull door panel, usually a nut on the inside, and a bolt through the latch area.(end of door) The rods pop off, you will see when you remove the door panel.
Old 11-08-2009, 11:07 PM
If we are talking full size Blazer pull the handle out of the hole and if you look up from the underside you will see that under the lock cyl there is a hole, about an eigth inch or so hole. If you push a poker or something up into that hole it will push a metal spring that will release the lock cyl. The lock cyl will go back into the door out of your way. Then, unbolt the latch so it falls down a little allowing the handle to be brought down (the rod from the latch to the handle is keeping it from going down) so you can get the arm of the handle out from the door.
The rod is attached to the handle with a clip that needs the flat part that goes over the arm*to be pulled out a little and slid off the arm releasing the rod.
*The arm has a small hole in it and the flat part of the clip has a little bent piece that goes into it.
Old 11-09-2009, 04:29 PM
thanx. got it
59 Chevy truck body on 80-85 Chevy frame? texczech General Rodding Tech 11 08-18-2011 09:24 PM
old chevy motor to new chevy truck pwchevyman1990 Engine 4 03-02-2009 01:36 AM
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 09:15 AM
s-10 front clip on a 50's chevy truck smokinbrinkman Suspension - Brakes - Steering 6 07-08-2008 12:48 PM
1967 Chevy Truck Gear Ratio 53chev Transmission - Rearend 3 01-27-2005 08:49 PM
