Chevy Truck Fuel tank relocating - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-16-2013, 08:59 AM
Originally Posted by PRHeloPilot View Post
I was thinking about using the rubber tube the original gas tank uses but when you say exhaust tubing are you talking about the metal pipes used in the muffler system?
If so I'm sure I could take it down the road to the muffler shop to have them bend a couple of pieces for me.
Yep the metal exhaust tubing. With a short rubber piece to connect it to the tank of course. I welded the tubing to the original filler tube so it was all metal down to the little "link" of rubber tubing hooking it to the tank.
  #17 (permalink)
Old 01-16-2013, 09:46 AM
Good idea, I'll keep that in mind because it's cleaner than dealing with the wood trapdoor.
  #18 (permalink)
Old 01-16-2013, 12:11 PM
ogre's Avatar
the 'Duracell Project'
a short wheel base 55-59 panel or suburban tank would be the ideal solution
though i suspect they are rare as hens teeth and no one repops them
could be used with the stock filler location on the 55-59 cab
the panel tank mounts in the frame next to the drive shaft
  #19 (permalink)
Old 05-30-2014, 09:05 PM
I got the fuel cell in for mock up and it fits great. I'm wondering if anyone has any ideas on how to strap it down?* I was thinking about making a cage of sorts under it. Here's what I'm talking about in the picture and put straps on the top.
Here's a pic of a mock up of sorts.
I had to call Summit Racing to tell them what inlet and outlet my fuel pump is so they can tell me what fittings I need to get to plum it. Which I'll be doing this week after the first.
  #20 (permalink)
Old 06-01-2014, 08:04 AM
I'm going to have the same issues when I install my aftermarket tank so I'm following this thread closely. Don't you worry the tank is exposed to potential damage so low?
89 Chevy fuel sender unstable Electrical 1 05-06-2010 07:08 PM
Gas Tank - help needed 48 chevy panel truck billymike General Rodding Tech 4 04-16-2009 10:40 PM
Looking for a 1947/1948 Chevy fuel tank 5cents Hotrodding Basics 2 12-01-2008 06:58 AM
86 Chevy c10 fuel cell help 77chevy400 Engine 2 10-13-2006 04:36 PM
fuel tank switch on Chevy 69elcaminoss General Rodding Tech 4 04-18-2004 01:27 AM
