Chevy truck oil pans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 12:12 PM
Gearhead forever's Avatar
I'm putting a '95 5.7L into my '87 Chevy P/U. Does anyone know if the oil pan config is the same on these motors? (Need to buy a new pan due to rust holes...need to get the right config.)
Thanks in advance
Old 12-28-2008, 06:20 PM
should be the same
Old 12-29-2008, 02:10 AM
SSedan64's Avatar
I think the newer engines come with a windage tray that mounts to the main studs. A pan for an older engine may not be deep enough in some areas, so when you pull the pan off the 95 check to see if there's a tray. Seems like someone else on here ran into a problem like that a while back.
Old 12-29-2008, 07:53 AM
Thanks, the 95 pan has a tray in it. I'll be sure to get the same one.
Oil leak in 350 Chevy Ed Baltera Engine 18 07-29-2012 11:24 AM
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 08:15 AM
Oil Priming - Chevy V8 - No Oil to Lifter Bores - Help leejoy Engine 4 03-09-2008 10:55 PM
chevy small block possible low oil pressure? ruski Engine 24 04-24-2006 09:18 PM
Oil smoke or....? 383 Chevy Finmike Engine 8 07-08-2004 05:25 PM
