Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy Truck problems
Old 06-19-2012, 04:55 PM
krypty krypty is offline
I have a 90 model Chevy full size truck with a 350 TBI engine i believe..The problem is that the previous owner had dropped an e clip inside the intake that found its way between the seat and the intake valve, anyways the head is junk...
Not wanting to spend alot of money on this, I have some options..
Find a new head for the 350...
Use a set of pre 87 heads on it, (I have these..) but i know the intake will not fit these heads.. These heads are 84 305 heads I had ported some time ago and have readily..
Does someone make a TBI intake for these heads? or can I drill the center four intake bolts and make it work? or just convert it to carb witch I have everything to do..Basically I have no budget for this.. So i will likely have to use what I have.
I dont know if the pre 87 heads have all the acc bolt holes for the brackets any and all info on this project would be greatly appreciated..
