Chevy truck rack n pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 03:46 AM
I put a 2001 Chevy 1/2 ton rack n pinion in my '88 1/2 ton and the steering is really stiff. Used the stock power steering pump. Do I need to change the pump pressure?? Any help would be appreciated.........
Old 02-22-2009, 08:17 AM
Chorny's Avatar
the 2001 more than likley uses a pump with variable assist,the 88 does not,most gm pumps put out 1100/1200 psi the variable assist pump changes the pump pressure more so at low speeds,like turning into a parking space,and less pressure at higher speeds,less required,hpoe this helps
Chorny
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 10:24 AM
Triumph tr-3 worm box swap with rack and pinion lugog Suspension - Brakes - Steering 1 06-29-2007 03:12 PM
looking for a pic - the Navarro (?) families 68/69 chevy truck lowROLLERchevy Hotrodders' Lounge 0 10-03-2006 03:24 AM
rack and pinion 1955 chevy truck chevy551958 Suspension - Brakes - Steering 1 09-20-2004 01:40 AM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
