chevy truck spring change - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2008, 09:35 PM
Jmark's Avatar
My '77 is in need of a full front bushing change and maybe ball joints and tie rods too. I noticed it's leaning to the right 1 inch sitting empty. (measured it).
I'm wondering just how much higher it would set if I installed new big block springs instead of the 350 springs it now has. Anyone know how much it will raise the front end? Or know the weight difference between a SBC and BBC?
Thanks.
Mark
Old 02-03-2008, 10:37 PM
Maybe an inch higher, assuming no sag in springs.So probabally 2-3 inches.
Shane
Old 02-04-2008, 08:15 AM
Jmark's Avatar
Thanks Shane. I"ve seen some 1/2 ton trucks really jacked up in the front. Don't want that! If I can find the weight difference between a SBC and BBC, I can put a scale on the drive way and then put a jack on it and jack it to that weight and then measure the difference.
Mark
Old 02-04-2008, 04:15 PM
SBC is around 550(iirc) BBC is around 685
Shane
New owner 58 chevy truck Lee Hester Introduce Yourself 5 10-29-2006 03:45 PM
56 chevy truck frame swap kid Suspension - Brakes - Steering 3 08-06-2006 05:45 PM
53 chevy panel truck huligar General Rodding Tech 12 04-27-2006 03:53 AM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 03:31 PM
1996 Chevy 1500 Truck 4.3 V-6 Juicer Engine 8 09-28-2004 06:06 AM
