Chevy Truck w/ 9" Ford Rear - Need Driveshaft Info - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 05:01 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Here I am again asking "stupid" questions. My project is a Chevy S10 (350/350 for now) that I narrowed the frame on and a 9" Ford rearend. I am not ready to install the driveshaft yet but was wanting to know in advance how I need to go about fitting the driveshaft into the 9" yoke. Do I need to replace the driveshaft end with one for a Ford or is there a special u-joint made for this swap?
Thanks
Old 04-08-2008, 05:31 AM
leldai73's Avatar
Its just metal,you're the boss
chances are theres a u-joint to fit the application. i have a u joint going from a stock Chevy drive shaft to a for nine inch rear. I'm pretty sure theres only a handful of sizes used for U-joints. maybe someone will chime in who knows a little more of the details. of you can try googling the subject or contacting a drive shaft manufacturer.
Old 04-08-2008, 07:20 AM
Stovebolter's Avatar
36 Chevy Low Cab
Last journal entry: C4 IRS
Thanks
Try these sites. They've got quite a bit of information on them. I've had a few custom driveshafts made for my Jeeps. A couple real odd-balls. They literally can make just about anything work with anything. On the 4X site, click on the tech tab at the top of the index page. Enjoy!
Dave
http://www.dennysdriveshaft.com/html/sitemap.html
http://www.4xshaft.com/index.html
Old 04-08-2008, 08:02 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
I believe NAPA carries a U-joint that for that also.
Old 04-08-2008, 11:44 AM
boatbob2
u-joint.........
Hi,i got my u joint from speedway.part chevy and part ford.
Old 04-08-2008, 12:39 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
They do make a u-joint that fits, all you have to do is measure the cup sizes and cross widths and go to a parts store with the dimensions. I know Precision makes one, I just don't remember the part number.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
1946 ford Truck Rear End HELP Jim1926 Transmission - Rearend 1 11-29-2005 03:50 PM
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 04:31 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 03:47 PM
Rear end swap for '53 Chevy truck Bruce H Transmission - Rearend 4 12-01-2002 12:43 PM
