Chevy Twisted Wedge Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2005, 08:31 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Ive seen Twisted Wedge heads for small blocks in various articles. Car Craft even has them listed in their cylinder head database on the web site, but I didnt see them in the TFS site or on the Summit site. Does anybody know anything about these heads, how much they cost, or where I could find more information about them? Just curious...
Also, how are the 23 degree heads compared to other aluminum heads?
Old 07-25-2005, 09:07 PM
benwantland's Avatar
I don't know about the TFS heads, and don't understand your second question - all stock and most aftermarket heads are 23 degree heads. Some expensive racing heads are 18 degree or less, but they're not terribly common, at least on engines I've been around.
Old 07-25-2005, 09:14 PM
Blazin72's Avatar
Wiki Edits: 19
I know that most of the Chevy heads are 23 degree. TFS has a set of heads called "Kenny Dutteweiler Signature Series" 23 degree. Those are the heads Im referring to.
Old 07-25-2005, 09:49 PM
We have used the Twisted Wedge R head on Fords and Chevy motors. They work excellent.
IN GENERAL all 23 degree heads are similar in design and operation. The variations come in the port design, combustion chamber and final finish of each. Compared to a non CNC'ed cylinder head the Trick Flows are very very good. Even compared to the CNC'ed head such as AFR they preform very well.
Old 07-25-2005, 10:19 PM
Blazin72's Avatar
Wiki Edits: 19
What port sizes on the R-series heads? Im going to be assembling a 406 and I plan on using aluminum heads. It's going to run somewhere around 10.5:1 compression with a solid lifter cam in the neighborhood of 245@.050. Im looking for a good set of heads to run and was considering the Twisted Wedge heads but I want to learn a little more about them first.
I was thinking about building a stroked 400 but I dont know how much you can cram into a factory SB 400 crankcase. It will have 5.7 rods and maybe 6" rods if they can fit without much work. Any ideas?
Old 07-25-2005, 11:06 PM
They are a 215cc runner. Not out of line for a strong 408.
Old 07-26-2005, 06:41 AM
firestone's Avatar
http://teamrfc.gospelcom.net
From what I have seen, the trick flows are good heads. I think, however, that for the money you would be better off with a set of AFR 210 heads.
Here are some dynoed packages with AFR heads. You will have around $150-$200 more in a set of AFR's but they come fully CNC ported.
http://www.airflowresearch.com/dyno/chevy_dyno.htm
Adam
Old 07-26-2005, 07:16 AM
edge's Avatar
Time is short, are you ready?
I think the "Twisted Wedge Head" you are referring to may not be manufactured anymore. They had a 185 cc intake runners and were economical aluminum heads and not "race" heads. Here is an article from Hot Rod that shows what I think of when someone says "Twisted Wedge Head" for small block Chevy. Not sure how old the article is, but if you can't find them on Trick Flow's or Summit's website, they probably are discontinued.
I had a set of those heads about 8 years ago. The intake valve had a 13* angle, while the exhaust valve used the traditional 23* angle. They worked okay, but I sold them and bought a set of Performer RPM heads. I learned that they had problems with springs breaking. Mine never did, but I dumped them anyway.
I concur with Adam, spend a few extra coins and get some AFR heads. That's what I eventually did and now run AFR 195 heads on my 383 SBC.
Good luck, Ed www.edgesz28.com
Old 07-26-2005, 05:41 PM
King of my Man-cave.
I have redone 3 sets of the 13/23 degree angle heads. The valves are almost impossible to find new and yep, almost all of the springs were broken or had broken dampeners. The newer 23 degree heads are infinitely better in performance and quality.
tom
Old 07-28-2005, 09:30 PM
trick flow heads
i own a set of the twisted wedge heads..they are great for a mild street motor, thats what they were designed for..i love them i have the dual spring heads (some were single) they work great for street mild strip, i am considering a lt1 motor so these might be available soon, they are not made any more but parts are readily available from tfs and many parts suppliers...what would you be willing to pay? i might pull them sooner.....
Old 07-28-2005, 09:51 PM
Blazin72's Avatar
Wiki Edits: 19
It is still going to be some time before I actually get around to assembling the engine. Im kinda in the "planning" stages right now and have been working a lot of overtime to be able to afford it too.
Old 07-28-2005, 10:01 PM
lluciano77's Avatar
I have a set of the Track Heat version of the Twisted Wedge heads. They are for small block Ford. They are very nice heads and gave my car more power than it can handle.
Old 07-29-2005, 02:54 PM
I have a set of the Trick Flow Twisted Wedge heads on the 350 in my street rod. It's a relatively mild motor and I've never had a problem with these heads, except that a standard Chevy valve cover doesn't seem to fit quite right. I don't think these heads are being made anymore.
chevy heads desireable for the rebuild of a 400 for my 3/4 ton 86 2x4. nh32u Introduce Yourself 4 12-17-2005 06:31 PM
Questions about heads for 355 rebuilt chevy 77 Monte Engine 1 01-16-2005 05:47 PM
#416 casting chevy heads, info Sagacious Engine 1 10-02-2004 02:19 PM
Chevy X heads? HemmiGremmie Engine 4 09-17-2004 11:37 AM
305 heads on 350 chevy serg18 Engine 3 03-26-2004 12:19 PM
