I assume you did the obvious and look for gas bubbles in the radiator. When the engine is up to operting temp., check the hoses for a pinhole leak. I had a car once with your problem and a hose had a leak so small that the water evaproated before it hit anything or had a chance to puddle anywhere. Only leaked under pressure. Weirdest thing I ever saw. Also, if your car has a plastic overflow tank, does it have a leak?
Try a pressure tester on the cooling system or maybe if you have access to an emmision tester hold probe just above coolant level run engine at cruise rpm, this should pick up any leaks between cooling system & cylinder, careful taking the rad cap off though but i guess you already know that!
Let us know what you find,
