chevy V-8 in a datsun 510? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2012, 01:25 PM
hey all, i am planning on purchasing a datsun 510 shortly and am looking at possible engine choices. i have been considering chevy V-8's. any thoughts or pointers on what will give me high power output while maintaining a low gross vehichle weight and most importantly, physically fitting in the engine bay would be greatly appreciated. i have seen a build using a chevy 305 but have also heard that wont produce near as much power as i might have hoped for. thanks!
Old 01-04-2012, 03:44 PM
305s are good for cruising or for something like a Tbucket. But a 383 has the same envelope dimensions and makes twice the power reliably.
Alternatives? Turbo EcoTec 4cyl. Turbo 4.3 (GMC Syclone) or Turbo 3.8 (Grand National) or the 3800SC (3.8L supercharged motor) all from GM
What about a Turbo Dodge 2.2L? Bolts to a dakota 5sp
Theres a Toyota 4cylinder from pick up trucks that makes good power too
Ford 2.3 SOHC turbos?
Old 01-04-2012, 09:32 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
The most popular swap in those is the sr20det end will give you more than enough power for that light car.
Old 01-04-2012, 10:01 PM
A Chevy V8 in a car that small would most likely throw the weight balance way off. Personally I would look for a lightweight aluminum turbo charged engine. Or what about a aluminum Buick / Rover v8?
Old 01-05-2012, 09:55 AM
There is a Chevy 265 in a Datsun pickup here and according to the owner/driver it has performed flawlessly for 40,000+ miles.
Normbc9
Old 01-05-2012, 11:30 AM
techinspector1's Avatar
Wiki Edits: 326
Most all small block Chevies made between 1955 and today are basically the same size motor, so it would make sense to begin with the largest block and crank size. The 305 was engineered for fuel mileage, with a very small 3.736" cylinder bore and 3.480" stroke (same as 350 Chevy). On the other end of the spectrum, the 400 was produced with a 4.125" bore and 3.750" stroke and was meant to power land barges in the Chevy lineup due to the torque available from it.
In my opinion, if you use a larger motor to begin with, such as a 406 or 383, you'll be way ahead of the game. You won't need as much static compression ratio or a big, lumpy cam or stiff gears. Build for power from just off idle to 5500 and have fun.
Old 01-14-2012, 04:37 PM
Banned User
i think alum heads, intake, waterpump and lightweight starter can keep the weight down for a sbc.
Also, i think the chevy 60 degree v-6 seems like a good combo and popular with this chassis?
74 Datsun 620 Bettybogle2011 Hotrodding Basics 4 09-17-2011 09:02 AM
71 Datsun Twisted Minis Hotrodders' Lounge 16 05-24-2008 12:13 AM
Engine swap Chevy 350 ina a Datsun 521 truck evh5150 Hotrodding Basics 17 09-12-2007 11:58 AM
Restoring a Datsun alex_0227 Hotrodding Basics 39 03-27-2007 03:04 PM
Datsun with a Chevy 350 DatsunTofu Engine 8 03-26-2007 10:49 PM
