Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy Water Neck Bolts Leaking
Old 03-31-2013, 10:51 AM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Originally Posted by SpeedRacer350 View Post
So, coolant is somehow leaking past the bolts. I know the holes are blind, so it must be seeping past the gasket. If so, I guess I'll try some Right Stuff sealant on another gasket and see if that does the trick. What do you all think?
If the holes are blind, they'd be unusual. Most go through into the water passage. I'd put thread sealant on the bolts, and also make sure intake and housing surfaces have sealant on both sides of the thermostat gasket.
