Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy Water Neck Bolts Leaking
Old 04-07-2013, 05:52 PM
SpeedRacer350's Avatar
SpeedRacer350 SpeedRacer350 is offline
Pedal Masher
Update: While at the track on Friday night, I took off the housing and reinstalled with a new gasket with Right Stuff on both sides and thread sealer on the bolts. I could only let it set up for about 30 minutes then had to go to tech. After making one pass it was still spewing coolant from somewhere. It's a new intake, I tried 2 new housings, and I'm using Mr. Gasket gaskets since I think they are more compressible than Fel Pros. Even if the intake was slightly not flat, the Right Stuff should have compensated for it. And it says that it's "ready to return to service immediately." I always seem to have the weirdest problems.
