Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy Water Neck Bolts Leaking
Old 04-07-2013, 07:00 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Maybe leaking somewhere else, sounds like you have pretty much covered the intake. Put a pressure test on the rad and pump it to 15 pounds or so, maybe you will see something. FYI I wont use anything that says Mr. Gasket on it, been burned more than once with thier chinese junk.
