Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy Water Neck Bolts Leaking
Old 04-24-2013, 04:17 PM
Northern Chevy Northern Chevy is offline
It can be hard to track down a leak when it only does it at high revs, exactly the time when the fan is moving air like crazy and blowing fluids all over the place.
Although an out of the box idea in tracking a leak down, if you could get your hands on a mini cam set with a recording color monitor and set them up at various angles in the engine compartment and do a run, then review it and see what you can see. So I am told some models will work in quite dark conditions. Definitely a unique way of putting your eyeballs where you physically can't !.
