We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 07-03-2006, 02:05 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Chevy Water Pump Byass Restrictor
http://carcraft.com/tipstricks/3027/index3.html
"Chevy Water Pump Bypass Mod
As a last resort on hot-running vehicles not equipped with a heater-water shut-off valve, restrict the small-block Chevy water pump bypass (arrow) by tapping it 1/8 NPT. Install a 1/8 NPT Allen-head pipe-plug, then drill a 1/4-inch hole in the plug to maintain some necessary bypass flow. This improves cooling by forcing more coolant through the radiator after the thermostat opens.
If the heater-hose fitting is at the rear of the engine near the distributor, you should also modify the thermostat to provide sufficient bypass circulation by drilling two 1/8- or 3/16-inch holes in the thermostat."
NOTE that it says only do this if you have a full flow heater that does not shut off water flow. Remember all the water going through that heater is NOT going through the radiator to be cooled. Early Chevys had 1/4 inch restrictors inside the heater hoses to prevent excess flow and to prevent blowing up the heater core at high rpms. X
Name:  chevy water pump from Car Craft.jpg
Old 07-03-2006, 02:11 PM
johnnya johnnya is offline
Looks like your link got mangled somehow. It shows info on AFB carbs.
JA
Old 07-03-2006, 02:14 PM
Classix_Lover's Avatar
Classix_Lover Classix_Lover is offline
Music soothes the soul
Ooo.. how embarrassing xntrik..
Old 07-03-2006, 02:26 PM
xntrik's Avatar
Old 07-03-2006, 02:39 PM
MAUSS MAUSS is offline
Not just early Chevies... my LT1 '94 Impala SS has a restrictor in the heater hose too.
Old 07-03-2006, 02:51 PM
xntrik's Avatar
Thanks, I didn't know that.
Back in the late 50s and 60s mechanics threw them away not realizing they were in the hoses, or in an attempt to get more heat out of the heater (I was raised way up there, -20* below) then in the summer lots of the cars would overheat. We just stuck in 195* thermostats.
Some genius came up with the idea of putting flow restrictors at the thermostat housing thinking that the water was going through the radiators too rapidly and did not have a chance to cool off. I think that this was the origin of the "old wives tale" about too fast of flow through a radiator.
Same thing happened to Fords, but lots of Fords used a restrictor orifice built into the manifold outlet fitting. I even saw geniuses drill those out larger. LOL.
Old 07-04-2006, 12:19 PM
Here's what it tools like, from the Advance Auto Parts web site: Flow Control
Old 07-04-2006, 02:34 PM
xntrik's Avatar
Thanks.
The old ones looked like a piece of 5/8 rod stock cut off 1/2 inch long with a hole drilled in the middle. Then it was inserted in the hose at the engine outlet. Should be installed on any hot rod to prevent heater core blowouts.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Chevy Water Pump Byass Restrictor"
chevy 350 blowing water pump gaskits out airwright Engine 11 08-31-2007 07:05 PM
where's the water pump?? mikeweyman Engine 9 07-05-2004 05:34 AM
Shimming pulleys out to match water pump pulley 406chevelle Engine 8 07-02-2004 09:36 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
water pump SLANT SIX Engine 6 01-15-2003 05:42 PM
