we I was told it should have that many miles on it, he had it for 10 years, but it sat for most of them, he sadi he was starting it once in a wile but I don't know how many of the years he did that.
and he said that he redid the valve tran a few times and at least one of them was with a new cam, and that might be it he did change the bearings, I'm going to see if I can back ahold of him to ask. and I did not say it had metallic oil. so now im thinking, ok I replaced everything that needed replacing, and it didn't run long enough to do damage, so I want to know the best way to clean it out to try to prevent it from happening over time now, or will it not anymore? |
look at the third picture, the front cam journal looks worn, and also the 4th lobe to the right looks a little light. look again as my eyes are not that good. what do you think? sam-missle |
If you have a dial indicator, mic each lobe across the low sides, then the the high side, subtract and that will give you the lift. Make a list of each one and see if any are off from the rest.
When you said the cam went flat, metalic oil is a given. Did the guy tell you it had a flat cam? Or???? Since there is no metal in the oil, at this point, the rest of the engine may be fine. |
ok, well I can see with my eyes that some of them are worn smaller, and theres like dotted pitting on the tops of some of them also.
thats why I was planning on a new cam & lifters anyway. and its possible that when most of the damage was done to the engine it was years ago, so the old owner might have changed the oil since thats point and I never woulda bin able to see it |
Got any pics of the cam bearings? tom |
ok thats good, so you think my engine is fine now, cause I was pretty scared for a wile when people started telling me I needed a rebuild lol
and I haven't pulled the bearing yet, and I cant get a good picture of the front one, thats why I didn't put it up already |
I see gouges on the bearing. It looks like they just shoved it in and scraped the bearings.
Looking at the rod bearing picture and the cam I would say the cam (at least this one) didn't go flat. The bottom of the cam bearing looks worn but not severely scored like some sort of failure went on. Possibly just too many dry starts. Check the bottom of all the lifters to see if the crown remains. If they do then that cam and lifters was working ok.
While it's where its at clean everything as best you can, replace the cam bearings and put it back together with the new parts you have.
BSE Racing Engines |
| Help Me Pick A Cam | Canadian Charlie | Engine | 2 | 11-16-2005 01:11 PM |
| 305 cam carb manifold | stickshift | Engine | 6 | 04-12-2005 03:46 PM |
| ball bearing bam bearings? | 87442lover | Hotrodders' Lounge | 4 | 06-16-2004 06:45 AM |
| Roller Cam Bearings????? | chevyelc81 | Engine | 3 | 11-20-2002 04:47 AM |
| Cam bearings | bigjoedo | Engine | 5 | 11-19-2002 07:14 PM |
