Chicago Electric Power tools - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2006, 11:18 PM
I was looking at the 4 1/2 grinders. Anyone ever have any problems with them? I have a makita now and its about 6 years old and still going strong, but I would love to get another grinders. So whats your take on the Chicago Electric stuff? Is it all crap?
Old 02-12-2006, 07:43 AM
cboy's Avatar
Last journal entry: Finished
I've experimented with some of the mid to high end grinders ($50-$100) and discovered they can be burned up just about as quickly as a Chicago, or in my case, even faster. So now I just have two $16 Chicago's from Harbor Freight. One to grind with and the other as my backup in the event number one blows up and I have to wait while a new one gets deliverd from HF.
Obviously, if you are using the tool on a professional level (6-8 hours a day) you will probably want to forget Chicago and go VERY high end. But for the hobbyist, I think the Chicago grinder is just fine and works out better financially than the big buck grinders. I also have the Chicago die grinder to run my burrs - and haven't had a lick of trouble with it.
Cheap- is- better clearly does not apply to all tools. But in the case of the Chicago grinders, my opinion is it does.
Dewey
Always learning...and sharing what I've learned.
Old 02-12-2006, 08:20 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Ive got a 4" for 10 years now Ive used it for metal going afar as using a 7" disk on it & Ive used it to cut ceramic & porcelain tile !
the switch on mine sticks some times .
For the $$ you can't beat it!
R
"SlowRide66"
"Illegitimis non carborundum"
Stinking Tools bukweet General Rodding Tech 37 04-30-2013 11:06 PM
No Power 4 BOLTS Electrical 4 01-17-2006 12:27 AM
Anyone Else use Milwaukee Power Tools? oldschoolrods Garage - Tools 11 04-13-2004 09:57 PM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 09:20 PM
Question about what tools to use for body work? clutter_1968GTO Body - Exterior 2 06-12-2003 08:57 PM
