Chilton's is failing me........ - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2007, 05:37 PM
Hey y'all!
The work on the Suburban goes on. Remember, this is a 1972 4x4 w/307. It looks like I'm gonna have to replace the fuse box, as for some reason, a whole bunch of them blew! I need to find a fuse box diagram, along with what size fuses were used for what function. I think that makes sense, lol.
Thanks!
Old 01-13-2007, 06:31 PM
Wiki Edits: 31
there is a '67- '72 truck wiring diagram in the Knowladge base here.
Old 01-13-2007, 06:34 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If you had a whole bunch of fuses blow at once...I'd suspect the harness not the fuse buss..
Carefully unwrap the tape from the firewall side and inspect the bundles..I suspect you'll find a BUNCH of them melted together..that is where you will need the repair if so.
Is your fuse box not marked? like under the fuse or on the box cover? If not, or it's not readable, get one (or write down the info) from one in the boneyard that is clear, that should help, I don't have a layout for a SUB of that year..
Here is one for a "blade type " panel for a GM truck..
and one for a "Glass type " fuse panel for GM truck...
Do either look like yours?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 01-13-2007, 06:55 PM
Electrical....got to love it
I've already contemplated the fact that I'm gonna have to rewire this truck! The previous owner, a twit with one too many beers in his system, got a hold of a pair of wire snips, lol. So I've already got the wiring diagrams saved on the computer. However the fusebox diagram is helpful. Unfortuneately, finding anything this old in a junk yard is a bit of a challenge!
This just joins the list of stuff to do...........but when I'm finished, it's going to be one heck of a truck!
Old 01-13-2007, 07:09 PM
boatbob2
fuze panel
Hi,if you have to rewire the surburban,pull all the wires and fuze panel out,and buy a complete new wiring set. there are a bunch of them in the hot rod,car craft,and street rodder mags. and there are a bunch of guys here at hotrodders .com that can tell you their experience with the various wiring kits.. im boatbob2
Old 01-13-2007, 07:15 PM
Wiring Woes
Hi Bob!
Yea, I've already been warned, lol. Found originals at LMC out of Lenexa KS! A whole lot less headaches for sure.
Old 01-15-2007, 12:28 AM
Might post at www.67-72chevytrucks.com/vboard & see if somebody there has one.
Old 01-15-2007, 03:09 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Someone on that board would have one. Those guys eat, sleep, drink trucks and 'Burbs from all years.
Old 01-15-2007, 07:41 AM
Monday
Thanks Jim, I'll have to do that. I know what you mean Kevin, lol, I like my Chevys too! Work'n on a '79 Blazer 4x4 as we type.
Old 01-15-2007, 07:16 PM
Last journal entry: Silverado Project
Need a Truck? U pull it parts
I got a 72 long wheel base, and a 89 chevy, the 72 needs a rear bed as someone smacked it right behind the drivers door....there are lots of them in this area in fields and just sittin around rustin away. There is even aplace called U-Pull-it Parts that has lots of trucks, some older than me...
Old 01-15-2007, 09:49 PM
hhhhhhmmmmm....interesting
Hey locknkey!
Whereabouts are you? I've found one '72 Suburban up here, just the body, no engine, but the salvage yard is trying to get a price that is only justified if it was fully restored!
Let me know.
Old 01-16-2007, 02:46 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If your going to have to rewire the whole truck anyway, and Can wait until your ready, order a Harness Kit from Ron Francis, or painless, or EZ .. They come with a new pre-wired Fuse buss along with the kit..and is a lot better than trying to "Graft" a used one in to a hacked system..
Doc
Innovations
Old 01-17-2007, 12:13 AM
not wanting to sell my 72...
But I did stay at a Holiday Express last night....(That darn commerical seems to be stuck in my head...)I PM you here about it....
Old 01-17-2007, 07:31 AM
Irelands child's Avatar
Originally Posted by docvette
Doc here,
Doc
And let me add American Autowire to the list - they have added some Chevy OEM replacements lately (I also am not a prewired panel lover such as E-Z and Painless have)
Dave
Irelands child
Symptoms of a failing distributor gear?? TurboS10 Engine 20 06-13-2005 10:35 PM
Power Steering Failing bigdtrucks Suspension - Brakes - Steering 1 03-31-2005 11:54 AM
Comp cams took care of failing cam TurboS10 Hotrodders' Lounge 12 01-08-2005 08:15 PM
anyone with a 94+ s10 chiltons manual ? lowROLLERchevy Electrical 7 04-19-2004 12:21 PM
Noisy failing Richmond T10 4 speed dannyboy02 Transmission - Rearend 1 06-12-2003 06:52 PM
