Chip off the old block... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2005, 09:33 PM
66Caprice's Avatar
Move It On Over!
I was looking over my old 350 and I noticed the lower front left corner where the P/S is mounted is broken off where the lower bolt mounts the P/S bracket.
I don't have to piece that broke off. It's a 010/020 block with casting # 3970010, and partial Vin# V1103CNR.
Is something like this reparable?
Thanks!
Old 05-21-2005, 11:11 PM
goth_rod87's Avatar
goth_rod87
yep...id say it is but you might have to cut the peice from another block depending on how bad it is...also it could get costly...but if it means that much to you then yes its doable just my opinion.
Old 05-22-2005, 12:30 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
I don't know if its repairable or not without that peice or not. But just an Idea, maybe you could make a bracket for the P/S? or Maybe one of those serpentine belt kits or something similar might be useful, Im not for sure on that as Ive never used one but just an idea.
Brad
Old 05-22-2005, 12:57 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
tough to say, a good welder can weld iron, or you can engineer a different kind of mounting bracket. How about posting a pic?
K
Old 05-22-2005, 08:36 AM
66Caprice's Avatar
Move It On Over!
Here's the pic:
You can see where it broke off at the lower P/S mount bolt hole. To the left is the timing chain cover.
I already have a new engine in the car, so this engine isn't that important. I was thinking about rebuilding it, but I don't want to if this isn't a economical type thing to fix.
Old 05-22-2005, 08:51 AM
I know there will be people that will say that this work but if it's something external like this I've had good luck with building up the area with a mig welder. Use very short beads, about 3/8", at a time and allow to cool a bit between each bead. Don't try to fix a cracked head or cylinder wall this way but simple things like this will normally repair ok.
Old 05-22-2005, 08:58 AM
Last journal entry: frame build
Not hard. A competent torchman can braze up a new boss that would be stronger than the original. I am leaving out most of the prep details. Thread a piece of 3/8" carbon rod with a coarse thread. Lay into the cleaned existing thread and build around it with brazing rod. The brass will flow into the thread on the carbon rod but will not fuse to it. When cool, screw the rod out and your done except for a little grinding and file work.
You would have to remove the timing cover and pan.
If you don't use the carbon rod the downside is drilling and tapping the new hole. Location is critical. The hole and bolt should be about a 1/4" longer than original due to softer thread.
Old 02-27-2012, 07:50 AM
same block
i have the same block in my 79 vette, same casting numbers and code. do you know what kind of block this is ? ive found many answers on this question, im looking for the real one.
Old 02-27-2012, 09:39 AM
bondo's Avatar
Dude,... This is a 7 Year old thread....
Cut it out....
Old 02-27-2012, 09:55 AM
btw
thanks for the answer, but its a 1970 350 block, the thread is 7 years old, does it mean that the answer will not be around anymore ? - lol
i'm looking for a better 400 s chevy block 406 ss monte Engine 3 08-23-2005 07:48 PM
i need a better 400 sbc block 406 ss monte Engine 5 06-21-2004 11:31 AM
396 Big block v.s. 400 small block Adrenaline_Fiend Engine 13 04-12-2003 04:14 PM
small block vs big block JUSTINH Engine 28 02-17-2003 04:37 PM
