Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-20-2003, 08:07 AM
jpd37 jpd37 is offline
Cool Chipped exhaust push rod tip
I replaced my valve seals and in the process discovered a chipped tip on No. 7 exhaust push rod. The motor is a stock 1970 sbc 307 c.i. I have purchased a new replacement push rod but it is about 1/32" - 1/16" longer than the old one. Will that cause any problems? Thanks for the advice.
Old 02-20-2003, 08:15 AM
bullheimer's Avatar
bullheimer bullheimer is offline
Hang Bush by 'is Nutz. He sux
Post re: Chipped exhaust push rod tip
well hey, howz things in BH? i just posted something about BH for the first time since i joined up. i went to BHHS in 69-71. if you went there then and might know me pm me. you can adjust the pushrod so that it depresses the plunger inside the lifter varying amounts, so i can see where you might just give that rocker arm an extra half a turn or something to even it out. but, i am not any kind of an engine builder so dont take my word for it!!! didnt know anyone in BH drove anything made in this country other than caddies and lincolns!
Old 02-20-2003, 08:21 AM
My BH is in Michigan. Is that where you are thinking? Thanks for the advice. I guess what I can do is install it, and do a compression check to see if it compared with the other cylinders. At least I will know if the valve is closing all the way. I just don't want to be jambin the valve into the piston.
Old 02-20-2003, 01:52 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
 1BAD80's barnstar
Like bullheimer said the lock nut will be turned back a little more, nothing should be hurt. Were you at the Woodward cruise?
[ February 20, 2003: Message edited by: 1BAD80 ]</p>
Luv the smell of NITRO in the morning.
Old 02-21-2003, 12:03 PM
Thanks 1bad80 for the vote of confidence. I have been to every Woodward Cruise since the event started. I cut my teeth on Gratiot though. I now am now close enough to Woodward that I can walk there in 15 minutes. Got my 37 Ply Sept 01, so now I cruise in the rod instead of the daily driver.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
