chips in cylinder walls - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2009, 09:19 PM
where the cylinder walls extend out into where the cam sits there are chips on the edges of the cylinder walls.. this is a chevy 350 4 bolt main out of a 77 3/4 pickup and im wanting to make a 383 stroker.. i bought it for $50 and im trying to figure out if its better to build it like im wanting to do or scrap it because of these chips in the cylinder walls. i can get pictures to explain better on what im talking about.
thanks Brent
Old 06-02-2009, 09:28 PM
302 Z28's Avatar
If your talking about the rough edges at the bottom of the cylinder that is normal.
Vince
Old 06-02-2009, 10:06 PM
Vince
the chips are half an inch wide and about a quarter inch chunk is missing out of each cylinder wall
Old 06-02-2009, 10:18 PM
ericnova72's Avatar
More for Less Racer
Bottom of every cylinder? Post up some pics.
Old 06-12-2009, 08:35 PM
sorry it took so long my computer crapped out
ID:	38711   Click image for larger version
ID:	38712   Click image for larger version
Old 06-12-2009, 08:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Looks a lot like what happens when a rod lets go. It's a little strange there are so many, but it might have been caused by the crank breaking.
If you have another core, trade this block off. Otherwise, as long as the block mags OK, I would just smooth out the edges of the chips and build it.
Check the main saddles real good- if the crank broke, you want to know all's good.
Old 06-12-2009, 09:00 PM
i know for sure the crank wasnt broke i removed it myself. one rod was broken, another was twisted other than that all others were attached.
Old 06-12-2009, 09:13 PM
ericnova72's Avatar
More for Less Racer
That is what happens when a rod breaks and pieces gp flying around. Like Cobalt said, IF it passes a magnafluxing, they can be smoothed up and the block re-used.
Old 06-12-2009, 10:29 PM
Hard to tell exactly, but it almost looks like they are where you would clearance for the rod/bolt on a stroker deal - like that was done without grinding... possibly with the rod itself. More than likely, a clean up with a grind would be the easy fix provided no unseen damage.
Cylinder ridge an inch down in the cylinder. What gives? DaSouthWon Engine 10 05-02-2009 05:46 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Theory: Intake volume vs cylinder volume / engine vacuum 59vette Engine 6 04-29-2004 12:03 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
chevy 305 cylinder relined DADDYBLUE Engine 4 02-13-2003 05:56 PM
