choke conversion help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2004, 05:51 PM
Hi I'm Bill,
Just need some help on an engine swap I'm doing. I'm takeing an engine out of an 86 chevy scottsdale and trying it into my 1972 chevy g10 van. I want to use the electric choke, but don't know how to set it up. I tried looking around to find out how to do it but all I have found were the kits. Seeing as though I already have the setup kinda I didn't know if was just a couple of wires I had to hook up or a bit more than that. Any help on this would be greatly appreciated.
I don't know if this helps, but it is a 4 barrel carb on a 350.
Old 05-05-2004, 06:08 PM
MI2600's Avatar
Member# 3287
Bill,
If you have a wiring schematic for the "new" truck, find a 12v source that's hot when the ignition is on. I found a source at the oil sending unit, but your wiring is probably different.
Some people cut into the key to coil circuit, but somewhere I heard it's not a good idea.
If you don't have a schematic, I'd go to the library and find a Chilton's or something similar.
The other wire on the choke housing is only a ground and is usually grounded somewhere on the carb.
Good luck.
Old 05-08-2004, 04:23 PM
Talking thanx
thanx for the help. I really appreciate it. I'll look inot that as soon as I can.
-Bill
