Choke Questions, - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2008, 12:33 PM
orvillewho's Avatar
Track & Street
Choke Questions,
So we put a new motor in a chevy, and the carb is an edelbrock with electric choke. I don't have a multimiter just a test light. So we found a wire that that was live when the key is on, and dead when the key is off. It gives a bright bulb on my test light, the same brightness as when I touch it to my live battery post. I know it is in-accurate, but with weaker amps it doesn't light up as much, goes dim. So the wire we are using is definetly 12 volts (if not more), same brightness as the live battery post.
We can not start the car yet, the radiator and plugs are still out, but we are putting them in today.
So here is my question, we had the battery hooked up to wire the choke, found a strong live wire, put a "plug" head on it so it slips on the prong out of the electric choke.
The wire is from the old Air Conditoner plug, (all the AC is removed ) It had four wires in the plug, three dead all the time, and a brown wire that was hot when the key is on, we used the brown.
So we hooked it up and turned the key over to make sure the "plug" head was getting power. It is, bulb very bright just as before. So we got power to it
So figured all was fine, went to make sure all wires were tight.
I touched the ground wire coming off the choke( yes it is grounded very well ) and the ground wire that sticks out of the choke was hot.
Is that ground wire suppose to heat up? I've never used an electric choke and I am just afraid it may be too much power to the choke.
Called dad, he said they are suppose to heat up the whole choke heats up to make the car warm up faster .
But is this normal, like I said we can't run it yet, but I want to make sure before we go and start it that I won't fry any wires. Is it possible that the choke it getting too many volts??
Thanks!
Old 03-25-2008, 12:45 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
This probably belongs in the elecrical forum. The choke is supposed to run off a switched ignition type circuit. And battery voltage (12.5v) is not too much for the choke.
The reason for wanting the power from the choke to turn on with the ignition is so that your choke isn't drawing power all the time.
You should be fine, it will start to heat up and gradually open the choke while the car is warming up and then you will tap the gas to take it out of high idle and you should be good to go.
Old 03-25-2008, 02:01 PM
sharpe427's Avatar
I think you mayt have been touching part of the bimetallic spring mechanism and yes, it is supposed to get hot. The spring (inside the choke housing) retracts as it gets hot (from the 12v power) and opens the choke.
Quadrajet choke adjustment questions MopaRV Engine 11 02-19-2013 08:27 PM
what kind of choke? 350c10 Engine 2 08-19-2005 09:16 PM
Choke light WakBordr7387 Electrical 3 06-16-2005 09:43 PM
Not running right-many questions... John McCabe Engine 5 10-26-2003 09:15 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 03:01 PM
