I am installing a used #8004 Weiand Dual Plane intake on my 350 Chevy. I am using an early Rochester Q-Jet carb that has a coil that opens and closes the choke. How do I set this up on the weiand intake? Do I simply make a bracket that bolts to the exhaust bypass or will I have to go to a manual. I realy hate to since my 57 had an automatic choke to begin with.
[ February 28, 2002: Message edited by: 57Chevyman ]</p> |
could you drill and tap the cross over? then run the tubing?
This is a easy one just go to a electric choke. You can buy a new one or just find a older GM car they all had them. I have put them on my cars for 15 years and they work fine and never stick. ROY
Do I buy one specific to my carb or are they a general part? Is it a gm part or is it available at my independent parts store. and how do I wire it in. I have had cars with electric chokes and I liked all of them except for the Veriable Venturi on my Ford LTD (Loved Towings Daily) at least until I replaced the carb
Mike sorry it took so long to answer still a little under the weather.You can get a aftermarket kit. Or just get a GM choke. All you need is 12v from the switch when the choke opens up it shuts the 12v off inside the choke.The only differance in the chocks is some stay on longer then others. You can adj it and make up for that. I always use a relay on the choke because I like the protection. ROY
Roys right,This is the best way to solve this delema, Get the electric choke as he suggested
NOVA JEFF |
