Choosing '75 454 timing set - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2017, 09:30 PM
I have a 1975 standard deck 454 out of a '1975 dually pick up. The motor is smooth and in good shape but I thought while it was out I would go ahead and replace the timing set and put new valve guide seals in.
Is there anything I need to know about choosing a double roller timing set?
I have heard the smog motors had retarded cam timing from the factory. If this is true, how do I make it better? Will ordering a timing set for a HP 69 big block assure that I get improved or correct valve timing?
OK guys. Educate this old dummy!
John
Old 04-21-2017, 06:34 AM
delawarebill's Avatar
timing chain
your point of retarded timing is unknown to me.. i never done a bbc. but one way to tell is pull the timing cover and ck the dots on both gears. crank at noon and cam a 6 is sbc. i'd also say a good double roller set is good.
Old 04-21-2017, 09:15 AM
John
Any BBC Mark 4 timing set for std rotation will work. No difference in them.
The Following User Says Thank You to StraubTech For This Useful Post:
John long (04-21-2017)
Old 04-21-2017, 08:00 PM
So, is the idea that the valve timing was retarded in the smog years a wives tail or was it built into the cam itself. If the latter is the case, would there be any advantage in a high performanc timing set that would allow me the advance the cam timing.
John
454 timing re-set, not running Wim van Andel Engine 9 03-12-2016 04:28 PM
Set timing on a '99 Chevy 454 ? moorwhine Engine 9 05-16-2012 05:08 PM
set timing on chevy 454 with HEI 71Nova454 Electrical 5 10-12-2010 08:14 PM
timing set replacement on 454 bbc bbcguy140 Engine 5 08-05-2010 07:07 PM
Need Help Choosing Cam And Timing Set 400smb_s10 Engine 1 06-11-2007 05:56 PM
