choosing the best cam for bbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2012, 01:47 PM
hey guys so i have a 454..750 cfm holley carb, 781 heads rebuilt stock, edelbrock rpm performer intake..the engine is pretty much stock, (not including these accessories) and plan to run it the way it is for now, but i want to throw in a new cam? what would you guys recommend? please help. the engine is on a stand and plan to run it in a few weeks once i have everything else hooked up..thanks alot
Old 09-18-2012, 01:59 PM
Have you considered having one custom ground?
Old 09-18-2012, 02:01 PM
what do you mean by custom ground?
Old 09-18-2012, 02:07 PM
the car im rebuilding is strictly street use..a weekend car to cruise and maybe even burn some rubber here and there..so i dont want a racing cam...maybe a cam that i can swap out without doing much or perhaps nothing to the valve train?
Old 09-18-2012, 02:34 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I deleated this sorry
Old 09-18-2012, 02:35 PM
[QUOTE=painted jester;1591759]This may help you understand a little about cam selection! I havnt been on the sight in weeks (been too busy). theres been some changes and ive been trying to post this for a long time!!LOL I hope it comes out ok
Ive had this from P.A.W. for many years on my shop wall.
Jester
file:///C:/Documents%20and%20Settings/Administrator/My%20Documents/My%20Pictures/MP%20Navigator%20EX/2012_06_05/2012_09_18/IMG.jpg
Ill try again I see it didnt post
Old 09-18-2012, 02:44 PM
Idk what your budget is but my local machine shop with my vehicle and engine specs will have a cam manufacturer grind a cam profile for my specific setup and use, a little more expensive but im the end its a little better than an off the shelf cam and its Taylored to ur setup
Old 09-18-2012, 03:15 PM
http://www.hotrodders.com/forum/newa...anageattach&p=
I dont understand why I cant post a picture is the site having problems
Old 09-18-2012, 03:37 PM
choosing the best cam for a BBC
What compression ratio do you have? If you don't know the compression ratio, what type of pistons do you have or part#? Has the block been bored and decked? Do you want to run a hydraulic or solid lifter cam? What kind of car or truck is the engine to be used in?
Old 09-18-2012, 03:54 PM
I hope it comes out this time? And I hope it helps you out!! If you click on it it will enlarge and then you can magnify it> This info is basic to all cams. the phone number is no good as PAW is down sized to only Chrysler parts Mainly Hemi's.
Your big block sounds like a very mild build so a range 2 duration is what i would recommend in whatever brand of cam you like as long as you stay in the range of duration suitable to your build you'll be fine.
Jester
http://www.hotrodders.com/forum/atta...1&d=1348002053
Old 09-18-2012, 04:49 PM
pay particular attention to spring pressures and installed height ( your heads are already done) so match them to the cam you order or you may have to redo them! Your cam lift may make it necessary to change push rods! your differential ratio and torque converter may need upgrading. If you go to a (range 2 or 3) bigger duration cam. So on the chart I posted pay attention to the particulars, like heads, compression, gear ratio, convertor, etc.
A custom grind is a little overkill on a basically stock engine! As many grinds and manufacturers that are available its just foolish to waste the money on a custom grind!!!!!
Jester
Old 09-18-2012, 05:14 PM
vinniekq2's Avatar
something like this,,,
120991-10 CL120991-10 275 275 221 221 .533 .533 110 106 Hyd. Hyd. 1
1400-5600 Good low & mid-range horsepower. Needs 4 barrel & headers.
Old 09-18-2012, 06:00 PM
prostreet6t9's Avatar
Differential/Driveline
Jester
^^ What he said!
The Following User Says Thank You to prostreet6t9 For This Useful Post:
vinniekq2 (09-18-2012)
Old 09-18-2012, 06:06 PM
vinniekq2's Avatar
I knew we would eventually agree on something pro
Check with Summit Racing to see if you can use your valve springs with this cam. Summit Racing SUM-K03052 - Summit Racing Street & Strip® Cam Kits - Overview - SummitRacing.com. I would buy the spring kit and use this camshaft. Summit Racing SUM-K1301 - Summit Racing® Cam and Lifter Kits - Overview - SummitRacing.com
Help choosing a balancer for intl balanced bbc? 540neverdone Engine 13 05-31-2009 03:54 AM
need help for choosing a cam chevrolet327 Engine 14 08-23-2008 07:59 PM
Choosing a cam taterror Engine 6 04-21-2008 02:42 PM
Need help choosing a cam! tmyster71 Engine 2 09-10-2007 07:28 AM
help choosing a cam beach_boy327 Engine 2 03-06-2007 04:39 PM
