Choosing a cam
could anyone recommend a good cam and intake. I have a 400 SB chevy .30 over with standard dish pistons. 5 speed tranny and a 3:08 ring gear. Thanks
all of the cam grinding companies have a "cam help hotline" on their web sites....(isky/crane/lunati/comp/howards/etc/etc)
contact 5 of them then analyze/question each for why they recommended whatever my $.02 leave the cam and motor alone.... swap to lower gears for alot more fun at ALL rpms...not just at peak HP rpms with a cam change... 400ft/lbs x 3.08 gears=1232ft/lbs twisting the tires 400ft/lbs x 3.55 gears =1420ft/lbs twisting the tires=15% more acceleration force |
im running a set of double hump 63CC heads, not sure about valve size. I would prefer running a hydraulic cam
Isky #201271 270 Megacam. Use Isky#205D valve springs.
Isky cam timing specs Degree in this cam on a 104 intake C/L. |
what compression ratio?
| Cam Selection and Dynamic CR | Arcuden | Engine | 10 | 03-23-2008 11:03 AM |
| I need cam help | 355s10 | Engine | 7 | 03-16-2008 05:34 PM |
| IGNITION and CAM TIMING | sum87mustang | Engine | 3 | 07-11-2003 07:52 PM |
| choosing a cam | 85 regal | Engine | 2 | 11-21-2002 11:53 AM |
| Roller Cam Help!!! | Vsanthos | Engine | 13 | 10-31-2002 04:29 PM |
