Choosing a camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2002, 07:16 PM
Post Choosing a camshaft
What is the advantage or disadvantage of a single pattern and dual pattern camshaft?
Old 08-08-2002, 12:19 PM
bullheimer's Avatar
NEVER use credit cards!
Post
dude, i got no friggen idea. but i do gotta subscription to Hot Rod. and the sept 2002 issue "Pick da Poifect Cam" say diss:"if your heads have exhaust to intake flow ratios under 70% (exhaust is 70% less of intake flow) then use a dual pattern cam to crutch the weak exhaust port. Over 80% you're in sngle pattern territory. (blower, turbo and nitrous motor generally prefer dual pattern grinds) Now, all you have to do is know this RATIO!!! Buhahahahahahahahahahaha! Maybe that means you find the area of your exhaust and intake valves and do the math. or is it diameter? square root?
Old 08-08-2002, 05:31 PM
HotRodS10's Avatar
All Throttle...No Bottle
Post
[QUOTE]Originally posted by bullheimer:
[qb]dude, i got no friggen idea.
LOL.....Man, thats my answer to the majority of the questions on this site. Anyway, I love that line dude, cracked me up when I started reading.
HRS10
[ August 08, 2002: Message edited by: HotRodS10 ]</p>
Old 08-08-2002, 08:41 PM
E.T. divided by $ spent= Speed
Post
Split pattern would be better if you have a restricted exhuast system or sucky flowing exhuast ports.Pretty much the way I gather it(this could get scary)If you have pretty equal flow in and out intake,heads,exhuast system use single pattern.If you have small exhuast pipes,cats or restricted mufflers use split profile.
