Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Choosing Gears To Go With A Magnum 280h Cam
Old 02-07-2013, 08:44 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
4.10:1 gears
1982 el camino
Th350 trans
2200-2700 stall why this undefined vague wishy washy stall range?
28" tire
mostly street some highways
The 280H will perform real well with a 10" 3200 stall and 4.10's. Generally off the shelf 10" high stalls come in two stalls
a tight 3000-3200 stall version and a higher 3500-3600 stall version.
You want one of these two converters. (If going drag racing pick the higher stall converter for the 280H cam)
A "2200 stall" is a stock GM 12" th350 converter. Not right for a 280H cam. Get a 10" converter.
The 280H does not get busy till 3000 rpm and does not like to idle nice in gear with a stock 2200 converter.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
the82elco (02-07-2013)
