Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Choosing Gears To Go With A Magnum 280h Cam
Old 02-07-2013, 09:01 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by the82elco View Post
Thats a lil too low i still want to be able to make a 30-45 min high way run
it is not too low at all with a 28" rear tire. The 280H cam does not like a low low cruise rpm. It will be very happy on the hiway with a 28" tires and 4.10's.
If you want a cruiser the 280H s too big.
Pick a cam with 218 to 222@.050"
Like a Isky 270H mega cam if you want a milder gears car.
270-270 221-221- .465-.465 108 104 isky #201271
Nice street cam.
Over a short 30 to 45 minute hiway run there is no fuel to be saved, by choking off the 280H cam with a gear that is less than it wants.
If you want mild gears. Change the camshaft to match that.
Remember, the engine does not care what you want. An the camshaft in the engine sets the whole personality of that engine
and how the car performs. That cam wants rpm.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
the82elco (02-07-2013)
