Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Choosing Gears To Go With A Magnum 280h Cam
Old 02-07-2013, 02:56 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by the82elco View Post
yea i like the 280h cam so im going to stick with it ill just change the converter & gears
If you like it and want to make it work get a 3500 stall 10" converter
and 4.10 gears. And get better cylinder heads than the 882's
They are the worst of the worst. No wonder you want to change things.
The 280H cannot make power with crappy 882 heads.
with the 882 heads, a shorter duration cam is much better.
The 882 heads ports are very very bad.
You have lots of other choices.
Been there.
