Choosing/ID'ing best 350 sbc from junkyard - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2009, 07:24 AM
I've got a mid 70's Nova that needs an engine. I had considered getting a garden variety GM crate motor, but I've decided to roll the dice and try to pick up a running 5.7 from a salvage yard and save a grand or so.
A large yard near me says they have several throttle body injection motors I can hear run for $550. I'm looking for guidance to make the best choice possible. I'd like to keep cost down, so I'll want to stay with the heads it comes with. I know the one piece rear seal and roller cam motors start in 87. But I also hear that doesn't mean it has a roller cam. Is there a way to tell without pulling the intake?
So what external clues should I look for to get the best 5.7 foundation that will get treated to the standard aluminum intake, carb, headers and cam upgrade? I suspect the big SUV's and trucks would carry the best mills.
Old 01-21-2009, 09:51 PM
SSedan64's Avatar
The TBI engines have crappy swirl port heads. 87up Cars had rollers but not trucks. Not sure when all truck got rollers tho'. I'd try to find a 96-99 Vortec truck engine, great vortec heads and have roller cams.
Old 01-22-2009, 06:11 AM
Will the 96-99 SBC require computer control? I don't mind plumbing in an electric fuel pump, but I'd rather not dive into rewiring the car if possible.
Old 01-22-2009, 09:31 AM
Why not get a crate engine if within your $$$book.. I would be honest and say to myself, "what actual mechanical skills do I have at this point in time" versus the money I will have to spend, versus a crate engine with a guarantee/warranty.. Gonna add up quickly if yah buy something from a boneyard and it don't turn out quite like you had envisionned..
Better to put out the dough once and dats it dats all!!!
T.
Old 01-22-2009, 09:50 AM
SSedan64's Avatar
If you're gonna use a carb you wont need any computer. Just need a Vortec style intake for the Vortec heads and Electric fuel pump. Vortec heads have a different mounting pattern for the intake, 2 bolts at each corner straight down. Save the intake bolts from the boneyard engine as they're vortec specific also. I'd recommend upgading the valve springs if you plan to intall a aftermarket cam.
Old 01-25-2009, 09:26 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I think they have carb kits for gen 3 (ls whatever) v8s. I think they even have dizzy kits too, so they're low-tech friendly.
...and a traditional dizzy looks a lot better than a bunch of coil packs and ECU wires stuck to the valve covers.
Old 08-22-2011, 09:44 PM
jmaine83's Avatar
hey guys pla
Old 08-23-2011, 07:10 AM
TroyBoy's Avatar
Psychomotors
I agree with SSedan.
Old 08-23-2011, 07:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
POST #18 has some info that will be useful to you at the junkyard.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
350 SBC: '70 top end on '90 block? Arcuden Engine 7 09-09-2005 12:49 AM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
350 SBC...specific years? 78SilverShark Engine 2 10-14-2003 07:20 PM
