Choosing a plug heat range - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2007, 11:05 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I'm building a vortec 383 and I'm trying to decide which heat range plugs to put in. I was thinking putting in plugs 1 step colder than stock to start and if they foul then go one step hotter.. Is this the regular procedure? Or do most people just run the oem plugs?
I plan on running only on 87 octane gas if that matters.
sbc 383
vortec heads
9.3 to 1 compression
XE262 camshaft (218/224)
performer rpm intake and edelbrock 600 carb
manual transmission
autolite 605 (5) is the stock heat range for vortecs
I was thinking of trying 104 (same plug but 1 steps colder)
Old 05-09-2007, 08:13 AM
go as hot as you can without detination. If it pings step it down.
Old 05-10-2007, 07:12 AM
autolite 605 (5) is the stock heat range for vortecs, autolite 605 (5) is the stock heat range for vortecs
GMs always run plugs hot, I would recomend going with a 103 first and if they foul out, go with the 104.
also, once you find a heat range that works, invest in some autolite XP style plugs, I run them and they last a long time. they are easy on the ignition system too, because they use less voltage to do the same job.
Spark plug heat range for N20? NGK 9? 67 Deuce 4 Me Engine 2 02-14-2007 12:58 AM
recomended spark plug.. screamin340 Hotrodding Basics 2 11-18-2005 07:17 AM
over heating delsman Engine 38 09-14-2005 08:32 PM
Spark Plugs Heat Range JoeDog Engine 1 05-11-2003 08:48 PM
spark plugs, changing heat range tips anyone? dmorris1200 Engine 2 02-20-2002 06:11 PM
