Choosing a powervalve - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2010, 03:11 PM
How should I go about choosing a power valve?
Old 04-30-2010, 03:31 PM
I usually take my vacuum at 800 R.P.M's and divide that in half .
Old 05-03-2010, 07:36 PM
I checked the vacuum with the car in gear and it was bouncing around between 6 and 7 inches. If I have a 6.5 power valve is that ok or do I need to go a lower? If is bouncing between 6 and 7 inches is there a possibility that my power valve is open when it is idling.
Old 05-03-2010, 08:25 PM
You usually want to go 2 inch's below that reading. So 6.5 with your gauge, I would go to a 4.5 power valve. Ken
Old 05-04-2010, 02:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What are the engine and cam specs?
I would be looking closely at the whole deal to see if I could get the idle vacuum up from where it is- 6 to 7 in Hg is in the range of a pretty "big" cam, duration and overlap-wise. So unless the cam IS big, there could well be ways to increase the idle vacuum and the idle quality and off idle response along w/it.
Old 05-04-2010, 02:37 PM
Banned
As Cobalt kind of eluded too, make sure your carb and ignition is properly tuned before reading your idle vacuum. That is a prett low vacuum, not too bad, and there are a lot worse out there, but with that low of a vacuum I'd maybe go with even a 3.5". If it is however more around 10" then a 4.5" would be fine, perhaps too small but it will help fuel economy.
Old 05-04-2010, 05:40 PM
need lots of timing at idle with a cam that big (7 inhg vacuum). at least 20 degrees at a 1000 rpm idle.
Old 05-05-2010, 12:17 PM
Yeah right now my car is idling at a1000 RPMs.
Choosing a spark plug... SeeMy355 Engine 10 08-10-2008 04:56 PM
Help Choosing Roller Camshaft For 454 Street Car leejoy Engine 1 11-28-2007 10:07 PM
Choosing a TIG KA67_72 Garage - Tools 4 10-20-2004 04:54 AM
powervalve jtdchevy Engine 6 04-04-2004 01:56 AM
