I would change rear ends.......completely A 9 inch Ford is the perfect rear end ......Strong, easy to work on and plentiful. You have spent $$$ on the OD, the engine and now The rear end...... The center section drops out the front ....so gear changes are simple....and I always have a few to choose from. Drilling the GM 5 on 4.75 wheel pattern is simple ( if you want the stock Camaro pattern........most wheels like Weld have two patterns ) And the Camaro is leaf springs so.....it is a easy conversion. There are lots of 9 inch Fords as narrow or more so than the Camaro..... DEUCE |
if i go ford 9", i'm probably going to buy a currie rear complete with new axles and go ahead and do a conversion to rear disc brakes, which i have a bunch of questions about that too, but i'll ask when i get there.
thanks for the advice, i was trying to talk myself into going to the ford 9" anyway |
I have a detroit locker in my ford 9" and love it, no clutches to wear out, and has been holding up to 500+hp. The Ford limited slip units never seem to last very long for me.
In fact I also have a Aerospace Engineering aluminum disk brake set-up im not using, if your interested. |
I have had excellent results in a street car with Factory Ford stuff. I have used a 65 Ford passenger car rear end housing and 31 spline axles. Sent the Housing out the be marrowed ( I use Moser Engineering but there are LOTs of choices ) and respline one axle and end up at 56 inches 56 inches measured this way... With a Detroit Locker ....my BigBlock Nova ( 3200 lbs. ) and a 4 speed could not kill it. The Nova went high 10's in basically street trim but with 10 inch slicks... The cost of narrowing a housing is around $125 and the respline axle cost is $75 ...so for $200.......plus the center section......you can be good to go... |
And you will like the 3.73 with the power you will be able to put down, along with the overdrive of the 700R4 giving you pretty decent mileage too.
I run the same combo in my car, and it chirps the tires on hard acceleration upshifts while giving me an average of 19 MPG too. |
| 8.8 Ford rear end in my 79 G body Malibu | 79 Malibu327 | Transmission - Rearend | 4 | 05-20-2007 02:26 PM |
| Hoods not shuting all the way | 74_Chevrolet | Body - Exterior | 5 | 09-01-2005 07:10 PM |
| Rear End ID | Riverman | Transmission - Rearend | 1 | 08-01-2005 07:21 AM |
| 63 biscayne rear differential problems | biscuit63 | Transmission - Rearend | 8 | 07-29-2005 04:37 PM |
| help with choosing rear tires | 71 chevy truck | Engine | 1 | 03-11-2003 07:52 PM |
