Choosing a rear end for a swap ... TECH - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2011, 02:20 PM
Swapping rear ends is a fairly common thing in the world of Hot Rodding. A lot of folks get in trouble because they do not know HOW to properly measure a rear end for a swap. A lot of rodders just measure from the backing plate to the backing plate and end up with a rear end that does not meet their expectations.
You should ALWAYS measure the rear end from the wheel mounting surface to the wheel mounting surface. That is the true width of the rear end.
The reason to measure this way is because brake drum widths and brake drum offsets vary, resulting in as much as 2 and 1/2 inches TOTAL difference ( or more ) if you measured from the backing plates.
DEUCE ... Moderator
Old 07-02-2011, 03:33 PM
ogre's Avatar
the 'Duracell Project'
this is from chevytrucks.org http://www.chevytrucks.org/tech/ifs&rearend.htm
scroll half way down for lots of older rearend width info
need tech help with trans and rear for 383 Stroker kieferrestoration Transmission - Rearend 6 03-28-2010 09:06 PM
Need a tech article on rear coilovers model A Daysgoneby Suspension - Brakes - Steering 8 05-14-2009 03:10 PM
choosing the proper rear end? weaz4200 Transmission - Rearend 10 10-31-2008 06:21 AM
Choosing the Rear william27103 Transmission - Rearend 5 10-27-2005 07:03 AM
help with choosing rear tires 71 chevy truck Engine 1 03-11-2003 07:52 PM
