choosing the right converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2004, 07:24 PM
im getting a trickflow trackheat topend package (heads ,cam, rockers ,lifters, etc)
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,700-5,700 RPM
Intake Duration 050 inch Lift 228
Exhaust Duration 050 inch Lift 234
Advertised Intake Duration 284
Advertised Exhaust Duration 290
Intake Valve Lift with Factory Rocker Arm Ratio 0.480
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.494
Lobe Separation (degrees) 110
Intake Valve Lash (in) 0.000
going into an 82-s10 /3.73's in the rear/SB 350
what stall conveter should i use?
i was thinking of getting this 2200-2800 stall i found at www.cnc-motorsports.com
its also going to be a DAILY DRIVER. I bought a Monster Motorsports Mega-Monster TH350 to go behind that 350, also with a tranny cooler
Old 10-04-2004, 09:09 PM
Siggy_Freud's Avatar
What size tires are you running with?
Bringing history and technology together.
Old 10-04-2004, 10:08 PM
lluciano77's Avatar
That converter should be just right. I went with the Trick Flow TW heads and the .542"/.563" lift cam. I have a 2,800 to 3,200 stall B&M Holeshot. It works great for launches, but the rest of the time it makes the car run like the tranny is slipping. Once it does start to lock up, I am going way faster than the rest of traffic. That isn't always cool.
