Choosing a Stall Converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2007, 07:55 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
G'morinin' fellas!
I am seeking experience on selecting a Stall Converter. The reason for this discussion is that when I look at Camshaft Manufacturer's Charts, of course most of them ask for Converter Stall to help you to select your Camshaft.
I have had a lot of combinations in Cars (Big Block 4 Speed/4.11 rear, Small Block Stall/Auto 4.11 rear, Small Block 4 Speed/4.56 rear, etc.). I have never had the combination that I am building-496, 700 R4, 3.55 Gears, 3000#, 29.5" tall rear Tire. I can't remember the "Rule"-lighter Cars can use a lower Stall-right? or is it the other way around ?
So, I am looking for ideas-it seems to me that a "streetable" Stall should be in the 3000 RPM and under Category so you can cruise and not have excessive slip-right? By limiting the Converter to 3000 RPM and under, it limits the Cam selection, but I do not want an unmanageable Beast here.
Does anyone here have a combination like I have? Can you tell me what you have and how much you like it? Give me our experiences!
Old 04-02-2007, 10:28 AM
Pick a cam that suits you purposes, then get a converter with the proper stall for the cam.
It shouldn't matter much if the stall is loose, because in high gear your converter will lock up on the TH700R-4.
On a side note, it seems to me that your rear end gears are a bit high for your application. With 29.5" tires and a 3.55 rear gear you'll be cruising at about 1985 RPM at 70 MPH. Even if you had 4.10's you'd only be running about 2300 RPM @ 70 MPH.
JA
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
Choosing the correct stall converter. cujoe822 Transmission - Rearend 3 09-08-2006 05:56 PM
please recommend me a stall converter smlblcks10 Engine 6 02-09-2005 05:41 AM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
checking stall on converter Checy_Guy Transmission - Rearend 1 07-21-2004 08:06 AM
