Are you sure it is a 32 and not a 33-34 pickup??
The 32 has the removable firewall, oval instrument panel mounted on "cone" which bolts to firewall, dashboard has oval hole and fits over instrument panel. Frame has the "smile" pressed into the siderail, runningboards are rubber covered, not diamond pattern, radiator shell has stamped oval in front for Ford emblem and no insert, just stamped steel bars, frame has K-member not X-member, 32 wheelbase is 106, not 112 as 33-34.
