Chop a top - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2012, 06:32 PM
Chop a top
Currently working on 1989 Ford Ranger.I would like to chop the top 2",need all the help I can get,would also like to see some pic's.Thanks L.Gallagher
Old 01-19-2012, 04:42 PM
good luck, chopping takes masterful metal work, See Street rodder magazine, plus whats your plan for glass afterward?
Old 01-19-2012, 07:12 PM
"afterward" is the of the biggest mistakes made doing a chop top, ask me how I know.
You chop the top, tack it in place. Then you cut the glass and make the top fit the glass! You can't modify the shape of the glass, you can however modify the shape of the metal. So you cut the glass, then make the top fit it.
Old 01-19-2012, 07:16 PM
The door and back glass by the way is tempered glass and can't be cut. So you need to make it new. Often the car is modified so flat glass will work (the original has a slight curve) and then you simply have a glass shop cut it out of flat safety plate (the glass with the plastic in between two sheets of glass).
66 chop help mathjew Body - Exterior 8 08-13-2008 07:57 AM
My 53 Chop top nosnorb Introduce Yourself 2 12-28-2007 01:34 PM
top chop welder2 Body - Exterior 2 03-07-2005 05:06 PM
Where can I get a chop done 50ChevySport Coupe Body - Exterior 3 11-24-2004 01:41 AM
Chop or not clarkdchevelle69 Engine 3 02-07-2004 02:09 PM
