Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chop the top on my 1947 Ford Pickup
Old 10-22-2010, 10:09 AM
hotwheels1 hotwheels1 is offline
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Well, i am a little nervous since this is going to be the first time i have ever done this. I kind of wanted to keep the top the way it is, but everyone i show it to says i should chop the top. So, what i have done so far is; i measured off of the frame up to where i felt the rear window of the cab could be moved down without allot of changes. I then took a level and walked around the truck with the level and drew a line where i am going to make the cuts. I too measured down 4" inches since i am taking that much out of the cab. My lines are now all the way around the cab and doors. Here are the pics of my layout and i will be cutting the cab off with a sawzall.
I know before i make the cuts that i need to reinforce the cab, so i will be using heavy rebar and weld it to the inside of the cab.
Wish me luck.......oh, and i added a picture of the rims i am planning on running.
ID:	49102   Click image for larger version
ID:	49103   Click image for larger version
ID:	49104   Click image for larger version
ID:	49105   Click image for larger version
