Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chop the top on my 1947 Ford Pickup
Old 10-22-2010, 10:36 AM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Just remember that on some chop's.. You have to cut the roof into 1/4's.. Because the roof get's narrower and shorter..as you move it down..
There is ways to get around the strip down the center and side to side..
The first one I did was on a 48 Chevy truck.. I used two cabs.. That way I didn't end up with a 2'' strip down the center and side to side.. I hope you under stand what I'm trying to say.. If you don't use two cabs.. You sometimes will have that strip down the center and side to side.. Good luck.. And this is where you will learn.. Don't be in a hurry, and it will all work out..
