Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chop the top on my 1947 Ford Pickup
Old 10-22-2010, 01:26 PM
hotwheels1 hotwheels1 is offline
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
I gotcha bro......after looking at tons of pictures, i planned on using a strip of metal down the center of the cab and door tops. Hopefully if i use one of those tools that can flange the metal, it won't look to bad across the top. Thanks a bunch for the heads up, i will see how it starts to look and if it gets to bad, i will find another cab.
Well the top is off. I checked and double checked my measurements, i removed all of the windshield molding and the glass. I welded in my rebar in a bunch of different directions for strength and removed the top. Here are the pic's with the top off of the truck.
I have to admit it was pretty scary making that first cut. After making the first cut and i relooked at what i was doing, i am pretty excited. I am going to be sure to take my time and make sure all of the metal lines up nicely, i hope anyways.......
ID:	49111   Click image for larger version
ID:	49112   Click image for larger version
ID:	49113   Click image for larger version
ID:	49114   Click image for larger version
