Originally Posted by hotwheels1
My only regret at this point is like new interiors pointed out about the rear window glass. When i first measured everything out, i was hoping to keep the original glass size
If you want to keep the back glass size.. Just measure how much you want to move it up.. Add that much to the top of the glass. cut it out and flip it over.. Weld it in.. it will be that much higher.. If you lay it out right it should work.. I would tack everything in place,, up to the back glass cut out.. Do a little figure.. and lay it out.. I think it should work by flipping the back glass..Or you can just move it where you want it.. And weld in a strip.. I hope you understanding what I'm trying to say.. I may have to get Brian to write this for me...
Just joking Brian..
Your much better then me on this computer..
And I would cut all new glass's..
