Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chop the top on my 1947 Ford Pickup
  #144 (permalink)
Old 11-11-2010, 04:26 PM
hotwheels1 hotwheels1 is offline
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Today i worked on the drivers side door. This one was a little tougher to do since it appears i cut on the wrong side of the tape with one cut, so i ended up with a 1/2" gap from the bottom of the door to the window frame. I used some some 22 gauge steel as a backing plate, drilled a couple holes and welded the backing plate to the inside of the window channel.....after several tacking and grinding events to get the right alignment...I think i ended up with a pretty decent door chop.
ID:	49954   Click image for larger version
ID:	49955   Click image for larger version
ID:	49956   Click image for larger version
ID:	49957   Click image for larger version
